Введение
The keyboard on a laptop can often times be damaged easily from accidental water damage or stop functioning from over-use. The keyboard can be removed with the release of 6 tabs and by gently releasing an attached cable.
Выберете то, что вам нужно
Turn the laptop right-side up and open the lid.
Locate the 6 black plastic tabs on the top edge of the keyboard that are holding the keyboard in place.
Инструмент, используемый на этом этапе:Tweezers$4.99
Starting in one corner, use tweezers to push the tabs inward to release the keyboard and then use the tweezers to gently pry the keyboard up and away from the laptop.
Repeat this step to each of the 6 tabs along the top of the keyboard. Use your blue plastic opening tool to keep the released sections of the keyboard up.
Once the keyboard is free, gently pull it towards you and lay it face down so the silver cable is visible.
Locate the two black tabs on either side of the base of the keyboard cable where it connects to the laptop.
Use the tweezers to push them both away from you in order to release the cable.
5 участников успешно повторили данное руководство.
