Введение
The goal of this guide is to help replace the motherboard in your Acer Aspire 5750-6677. The motherboard is an essential component to any computer. The computer’s motherboard provides a platform for communication between the central processing unit (CPU) and memory, as well as providing connection points for any additional input and/or output components. Replacing the motherboard is considered to be difficult and will require approximately 1 hour to complete and the only tool you will need is a Phillips #0 screwdriver.
Выберете то, что вам нужно
Flip the device over so the backside is facing up.
Remove the two screws with the Phillips #0 screwdriver.
Start by flipping the device over to expose the screws.
Remove ten screws with the Phillips #0 screwdriver.
Using a Phillips #0 screwdriver, remove the four screws found under the battery.
Flip the laptop back around so the Acer logo is facing upwards.
Open the laptop and using the iFixit opening tool, press the tabs in at the very top of the keyboard, in order to remove the keyboard.
Use the Phillips #0 screwdriver to remove six screws.
Pull the top off of the keyboard to expose the motherboard.
Remove the seven screws using the Phillips #0 screwdriver.
Detach any wires or cables that are attached to the motherboard.
Remove the motherboard.
2 участников успешно повторили данное руководство.
