Введение
This guide will show you how to replace the speakers of your Acer Aspire 6530-6522 in case of damage or malfunction.
Выберете то, что вам нужно
Make sure the device is unplugged and completely powered down.
Turn the device over.
The lock switch can slide either towards or away from the battery. If it is pushed towards the battery, the release switch is locked and the battery can not be released.
Slide the switch away from the battery.
The battery release switch is just to the inside of the battery and slides parallel to it.
Push the switch to the side. It is not just an open or close switch, it actually pops the battery up so you will feel some resistance.
Remove the three 3.5mm screws securing the subwoofer using the Phillips #1 screwdriver.
Remove the two 4.5mm screws securing the speakers on either end.
