Введение
Is your computer not loading properly? Consider using this guide to replace the RAM in your device.
Запчасти
  1. Begin with the bottom of the laptop facing up.
    • Begin with the bottom of the laptop facing up.
    • With a screwdriver, unscrew the four phillips #0 7.5mm screw around the bottom panel.
    • Lift the panel at the top and pull towards you to remove it from the laptop.
  2. The memory should be to the right, after you have removed the bottom panel.
    • The memory should be to the right, after you have removed the bottom panel.
    • Towards the bottom of the memory card, push outwards on the two small silver levers to release the memory card.
    • Pull the memory card out towards you to remove it.
Заключение
Amy Endo
Участник с: 22.10.2018
186 Репутация
1 Guide authored
Команда
UC Davis, Team S11-G4, Lore Fall 2018 Member of UC Davis, Team S11-G4, Lore Fall 2018
UCD-LORE-F18S11G4
4 членов
Автор 4 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 1
За 30 дней: 4
За всё время: 33
