Введение
For this guide you will need a phillips screwdriver. Before beginning, make sure you completely power down your laptop and remove the battery.
Выберете то, что вам нужно
Using the Phillips #1 screwdriver, unscrew the single screw and remove the cover.
Push the side of the clips away from each other to release the RAM. Remove the RAM from the device.
Почти готово!
Заключение
