Введение
The fan helps circulate air through a laptop and cool off important pieces. A broken or dirty fan can cause overheating.
Выберете то, что вам нужно
Insert a spudger into the battery release latch.
Slide the battery release latch to the right, this will eject the battery for safe removal.
Using a Phillips 1 screwdriver, remove the 17 9 mm screws from the bottom of the laptop, including the one in the back panel.
Using a plastic opening tool, carefully remove the back panel.
Remove the 9mm screw under the back panel.
Using a plastic opening tool, carefully separate the frame along the edges of the laptop. This should separate the keyboard assembly from the bottom portion of the laptop.
Инструмент, используемый на этом этапе:Tweezers$4.99
Open the laptop, leaving the screen flat on the table.
Carefully pull the keyboard assembly out away from the base of the laptop. There should be three connections visible in the gap between the keyboard assembly and the base.
Using tweezers, carefully detach the connections from the base.
Place the keyboard assembly and the disk tray place holder aside.
Remove the six wire connections to the motherboard.
Remove the tape connection by lifting the plastic black holding piece and carefully pulling the tape out of it's slot.
Using a Phillips 1 screwdriver, remove the two 5mm screws from the motherboard.
Using a Phillips 1 screwdriver, remove the black 5mm screw from the fan.
Using a Phillips 1 screwdriver, remove the black 3mm screw from the WiFi card.
Flip the motherboard over so that the back is face-up.
Unscrew the three 5mm screws and lift the fan off of the motherboard.
