Введение
The RAM card should be replaced if the computer has memory issues. This is sometimes the problem when the computer won't boot or is running too slowly.
Выберете то, что вам нужно
Insert a spudger into the battery release latch.
Slide the battery release latch to the right, this will eject the battery for safe removal.
Using a Phillips 1 screwdriver, remove the 9 mm screw which secures the back panel.
Locate the tabs on either side of the RAM card.
Push out on both tabs simultaneously to release the RAM card.
The RAM card should raise slightly at the unattached edge.
Еще один человек закончил это руководство.
