Выберете то, что вам нужно
To release the battery, depress the battery release with a nylon spudger. Hold the latch down and slide it over.
Grab hold of the plastic tab and pull the hard drive away from the connectors. This will release the hard drive.
Remove the fourteen M2.5x8 screws highlighted in the picture with a PH0 Phillips screwdriver.
Rotate the back cover up a little to reveal the cables connected to the motherboard.
Unplug the cables by sliding them out of their receptacle.
Remove the four center panel M1.6x3 screws with a PH0 Phillips screwdriver.
Remove the two M2x3 screws with a PH0 Phillips screwdriver.
Use the plastic opening tool to slide the metal part out to release it from the retaining tabs.
2 участников успешно повторили данное руководство.
