Введение
Keyboard mistyping, keys not working, or keys jammed? This guide shows how to remove the keyboard on an Acer Aspire E1-531-2438.
Выберете то, что вам нужно
Turn the device over so the back side is facing up.
Using a spudger, slide the orange latch to the right. This will release the battery, which should pop up from the device.
Use two hands tilt the side of the battery closest to the orange latch upward as shown in the images.
Tilt the side of the battery closest to the orange latch upward.
Lift the battery up and out of the device.
Using a Phillips #0 screwdriver, remove the two 9mm screws on the access panel.
Using the indentation, pry open the access panel with your fingers or a spudger.
Remove the access panel to expose the hard drive, WiFi chip, and RAM modules.
Grip the plastic tab on the hard drive, then pull to the left to unplug the drive from its socket.
Once free from the socket, lift the hard drive up and out of the device.
Using a Phillips #0 screwdriver, remove all of the following screws:
Fifteen 9mm screws
One 6mm screw
Three 3.5mm screws
Remove the optical drive by sliding it out of its slot on the side of the laptop.
Using a plastic opening tool, pry along the seam running the perimeter of the laptop to separate the bottom case from the palmrest assembly.
Flip the device over and open the laptop so that the keyboard is visible.
Lift up the palmrest assembly just far enough to access the connectors underneath.
Using a pair of tweezers, disconnect the small white ribbon cable from the connector near the left side of the device.
Disconnect the large black ribbon cable near the middle of the device. Gently pull on the cable away from you.
Using a spudger, release the keyboard by prying at the indicated points.
Remove the keyboard from the palmrest assembly.
