Введение
This manual will help you if you want to change or uprade your SATA HDD to SSD or DDR3 RAM Module or if you want to replace your not working WiFi card.
When you doing this, do not rush !!!
Инструменты
Запчасти
Детали не указаны.
Видео обзор
Drag the SATA HDD to release it.
Unscrew 4x screws to remove the disk from the HDD Caddy Holder.
Use plastic tool to release the DDR3 RAM memory module from the locking clips.
The RAM memory modules have a key notch position to prevent putting the board incorrectly.
To release the Half Mini PCI WiFi card, unscrew the screw and disconnect the coaxial antenna cable.
Did you do it successfully?
9 участников успешно повторили данное руководство.
