Выберете то, что вам нужно
On the back of the laptop, there is a sliding lock. Push the slider and the battery will unlock
Remove the 1 screw just above the battery with a Phillips #1 screwdriver.
Remove the 17 Phillips #1 screws remaining on the back side of the laptop
Flip over the laptop, Using the spudger separate the body of the keyboard from the base of the laptop.
Carefully lift the keyboard and disconnect the 3 ribbon style connectors from the computers boards.
Press down on the spring clips on either side of the ram, It will unlock and can be removed
