Введение
Without WiFi you can have a hard time getting connected to the internet. This guide will show you how to replace a broken internal WiFi card.
Выберете то, что вам нужно
Place the pointed end of a spudger into the battery lock. Slide the battery lock to the left using the spudger. A "click" sound will accompany the release of the battery.
Carefully pry apart the clips holding the keyboard in place by moving a metal spudger along the seam.
Carefully flip up the white hinge. Then, detach the three ZIF ribbons connected to the motherboard.
Remove the panel with the keyboard and the touchpad.
Locate the two antenna cables shown.
Using a plastic opening tool, remove both antenna cables from the WiFi card by gently prying them up.
Remove this 3 mm Phillips #0 screw and the WiFi card should pop up.
Gently lift WiFi card off of the motherboard.
9 участников успешно повторили данное руководство.
7 Комментариев
Very well done - thank you!
np. im glad it worked for you. could you post the exact model you have and was there anything I missed?
Great guide. I would just like to mention a difference I found. My laptop had white connectors and the hinged lock latch was black. So I guess all assemblies aren’t identical. Also, the large connector for the keyboard did not have a locking latch. My model is an E5-571P manufactured 2014/09/15.
Hi, I want faster Wifi. Which Wifi card do I need to replace for a Acer Aspire e15 e5-571-58E6?
Hi I just bought an upgrade, so I’ll tell you which one I got and if it worked when I get it in the mail in a few weeks.
Matt -
