Введение
If your device is overheating, you may need to replace the laptop's CPU Fan. This guide will help you through this process.
Выберете то, что вам нужно
Flip the laptop over and locate the battery release switch.
Insert the pointed end of the spudger into the battery release switch.
Push the battery release switch to the right.
While the battery release switch is pushed to the right, carefully slide the battery out of its socket.
Use a JIS #00 screw bit to remove the marked screws around the CPU fan.
Carefully remove the CPU fan.
