Введение
A faulty power jack may be causing your laptop to not charge properly, and it may need to be replaced. This guide will help you through this process.
Выберете то, что вам нужно
Flip the laptop over and locate the battery release switch.
Insert the pointed end of the spudger into the battery release switch.
Push the battery release switch to the right.
While the battery release switch is pushed to the right, carefully slide the battery out of its socket.
Disconnect the opposite end of the power jack from the motherboard by carefully pulling the wire.
Lift the bottom right side of the screen to move the metal plate covering the power jack.
Еще один человек закончил это руководство.
