Введение
The motherboard in your Acer Aspire E5-571P-55TL holds all of the other parts together, and allows for communication between hardware components. With a non-functional motherboard, your laptop will have many problems. To see common issues which may require motherboard replacement, see our Acer E5-571P-55TL troubleshooting guide.
This guide will explain how to replace the motherboard for the Acer E5-571P-55TL. Before performing actions in this guide be sure to power off your laptop and remove the power adapter.
Выберете то, что вам нужно
Place the Spudger into the battery lock and slide it to the left until you hear the battery unlock.
Using a Phillips #0 screwdriver, remove each of the eighteen 8 mm screws from the bottom of the laptop.
Carefully place your fingers underneath the top of the keyboard just below the screen.
Pull upwards until you can hear the keyboard click out of place.
Continue around the entire laptop, carefully pulling the keyboard and palm rest assembly slightly from the frame to reveal the ribbon connectors.
After the keyboard is detached, unplug each of the three ribbon cables and remove the keyboard and palm rest assembly.
Using a Philips #0 screwdriver, remove the two 3 mm screws from the corners of the Wi-Fi card.
Carefully lift the network card from it's slot, and disconnect the two coaxial cables.
Using a Phillips #0 screwdriver, remove the two 8 mm screws holding the hard drive carriage in place.
Carefully unplug the ribbon cable running across the hard drive carriage and place it to the side.
Remove the hard drive by sliding it to your right, away from the motherboard, next pull the hard drive towards yourself and away from the laptop.
Once again using a Phillips #0 screwdriver, remove the two 3 mm screws highlighted on each side of the hard drive case.
Open the hard drive case to replace the hard drive.
With a Phillips #0 screwdriver, remove the two 4 mm screws from the motherboard.
The last connection to the motherboard is the screen. Gently disconnect the cable from the motherboard.
Lift the motherboard up from the top right corner, and then pull it right to release it from the case.
