Введение
This guide will show you how to replace an old or faulty battery on the Acer Aspire E5-573G.
Выберете то, что вам нужно
Run a pick between the bottom cover and the device around the edge of the laptop and unclip the cover from the rest of the device.
Lift the left side of the bottom cover, but do not completely remove the cover, as the speaker is cable is still connected and will be damaged.
Pull the speaker connector towards the fan to disconnect it from its socket on the motherboard.
Pull the battery connector towards the battery to disconnect it from its socket on the motherboard.
Remove the battery.
14 участников успешно повторили данное руководство.
Один комментарий
Where can i buy a battery replacement for my aspire e5-573g-59c3?
