Введение
When removing the network card, be sure to note the positions of the black and white cables on the network card before removing them to ensure that you put them back in the correct space.
Выберете то, что вам нужно
Unscrew the 13 6.2mm screws located on the bottom of the laptop using the JIS #0 screwdriver.
Unscrew the one 6.2mm screw in the upper left-hand corner of the network card.
Remove the black and the white cords from the network card.
Slide the card out of the motherboard and replace it with the new one.
