Введение
To replace the RAM is an in-depth procedure as it's located under the motherboard. There are a lot of screws from the various parts but they're all the same size so it doesn't matter where they go back in.
Выберете то, что вам нужно
Unscrew the 13 6.2mm screws located on the bottom of the laptop using the JIS #0 screwdriver.
Locate the small black button surrounded by a white circle near the battery on the motherboard.
Press and hold the button for five seconds.
Using your fingers or the small plastic opening tools, disconnect the battery connection from the motherboard by pinching and pulling back on both sides of the connector.
Locate the two 6.2mm black screws holding the battery in place and unscrew them.
Gently lift and remove the battery.
Locate the hard drive and slide the hard drive to the left until it disconnects from the mother board.
Unscrew the one 6.2mm screw in the upper left-hand corner of the network card.
Remove the black and the white cords from the network card.
Slide the card out of the motherboard and replace it with the new one.
Gently push the two metal clips that hold the RAM to the side, as indicated by the picture.
It should pop up once done.
