Введение
When removing the screen border, make sure to take caution to not damage the screen itself. When removing the screws from the screen, ensure you have a safe space to put the screws as they are very small and easy to lose.
Выберете то, что вам нужно
Open the laptop screen to the farthest back position
Using the plastic opening tool, pry off the screen border and completely remove it.
•Using the JIS #1 screwdriver, remove the 4 3mmscrews from each corner of the screen
Carefully pull back the tape on the connector until the connector is fully revealed
Carefully remove the connector from the old screen and connect it to your new, compatible screen
To reassemble your device, follow these instructions in reverse order starting from Step 3.
2 участников успешно повторили данное руководство.
