Выберете то, что вам нужно
Видео обзор
Grab a spudger and work your way around the outer edge of the screen
Lean the screen all the way back to remove the plastic frame from the hinges at the bottom
Unscrew the 4 screws around the edge of the screen
Lean the screen all the way forward on to the keyboard
Peal up the sticky tape next to the screen connector
Pull the connector down carefully away from the screen and disconnect it
connect the new screen and screw back in place
Turn on the screen to test before putting the screen frame back on
Tilt the screen all the way back and push the frame back on hinges 1st.
Finally lean the laptop on its edge and clip the back on the hinges back in place.
Еще один человек закончил это руководство.
