Введение
You may need to replace the fan in your Acer Aspire ES1-512-C80E if you experience problems such overheating or loud noises. To do this, you will need Phillips #00/#000 screwdrivers, and a spudger. Additionally, you will need a replacement fan. To access the fan, the back cover of the device will need to be removed. The process of replacing the fan should take between 15-25 minutes.
Выберете то, что вам нужно
Place the device upside down on a flat surface.
Using a Phillips #00 screwdriver, remove all nineteen 1.2mm screws that secure the bottom cover of the device.
Using a Phillips #00 screwdriver, remove the four 1.2mm screws from the keyboard.
Using a spudger, go around the edges and pry off the keyboard.
Remove the ribbon cable connection from the keyboard.
Peel back the two pieces of tape to separate the keyboard.
Remove the keyboard from under the plastic covering.
Remove the silver plate back cover of the keyboard from the bottom base.
Remove twelve 1.2mm Phillips #000 screws from the motherboard, wireless LAN card, and hard drive.
Using a Phillips #000 screwdriver, remove both 1.2mm screws that hold the fan in place.
Lift the fan, hard drive, motherboard, and wireless LAN card out of the device.
These components are still connected with wires. Remove all plugs that may be attached to other components in order to isolate the group of components.
Flip over the motherboard.
Remove all three 1.2mm Phillips #00 screws that attach the fan to the motherboard.
The fan and motherboard are still connected with wires. Remove any plugs that may be attaching the components
Remove the fan from the motherboard.
2 участников успешно повторили данное руководство.
