Введение
You may need to replace the motherboard on your device if you experience problems regarding the Acer Aspire ES1-512-C80E’s run speed. To do this, you will need Phillip’s #00/#000 screwdrivers, and a spudger. Additionally, you will need a replacement motherboard. To access the motherboard, the back cover of the device will need to be removed. The process of replacing the motherboard should take between 15-25 minutes.
Выберете то, что вам нужно
Place the device upside down on a flat surface.
Using a Phillips #00 screwdriver, remove all nineteen 1.2mm screws that secure the bottom cover of the device.
Using a Phillips #00 screwdriver, remove the four 1.2mm screws from the keyboard.
Using a spudger, go around the edges and pry off the keyboard.
Remove the ribbon cable connection from the keyboard.
Peel back the two pieces of tape to separate the keyboard.
Remove the keyboard from under the plastic covering.
Remove the silver plate back cover of the keyboard from the bottom base.
Using a Phillips #000 screwdriver, remove the five 1.2mm screws that hold the hard drive in place.
Lift the hard drive, fan, motherboard, and wireless LAN card out of the device.
These components are still connected with wires. Remove all plugs that may be attached to other components in order to isolate the group of components.
Once the four components are out of the device, the hard drive is ready to be removed.
To remove the hard drive, unplug it from the motherboard.
Flip over the motherboard.
Remove all three 1.2mm screws that attach the fan to the motherboard using a Phillips #00 screwdriver.
Lift the fan off of the motherboard.
The fan and the motherboard are still connected with wires. Remove any plugs that may be attaching the components.
Remove the wireless LAN card from the motherboard by unplugging the connecting wires.
To remove the RAM, push both of the clips outward and the RAM chip will easily slide up and out.
Еще один человек закончил это руководство.
