Введение
This guide will lead you through the steps of replacing your screen on your Acer Aspier ES1-711-P1UV. The screen may need to be replaced if you are having issues seeing images on the screen.
Выберете то, что вам нужно
Place the laptop face down on a flat, clean surface.
Remove all twenty-seven 7 mm screws on the back cover of the laptop with a Phillips #0 screwdriver. Screws are circled in red on the diagram.
Use the iFixit opening tool to pry open the four corners of the back cover of the laptop. You may need to use your hands to fully remove the cover.
Be sure to evenly apply pressure when removing the back cover.
Disconnect the colored bundled cable connectors from the motherboard. To do this, pull on the wires to disconnect the cable and remove the battery.
Place the laptop on a flat surface and open it to see the screen.
Using your fingers or a plastic opening tool, pry open the bezel that holds the screen in place.
Use the Phillips #0 screwdriver to remove the fourteen 5mm screws around the screen.
Use the Phillips #0 screwdriver to remove the four 4mm screws holding in the screen.
With the screen on the paper, detach the Zero Insertion Force (ZIF) connector attaching the screen to the video cable inside of the front cover.
Gently remove the screen from laptop.
Еще один человек закончил это руководство.
