Введение
This guide will explain how to safely remove the Acer Aspire M5-583P-6423 RAM in order to replace it. To avoid harming any components, you’ll need the iFixit opening tool and a Phillips #00 screwdriver. The steps are not difficult, but it’s important to follow all of them as they are mentioned.
Инструменты
Запчасти
Turn the computer off and close it. Disconnect the charging cable from the laptop and place the laptop upside down.
Remove seventeen M2.5x8mm screws on the back cover of the laptop with the Phillips #00 screwdriver.
Push the back cover up from each side using the iFixit opening tool.
Once the back cover is separated, you’ll see all the internal components of the laptop.
Pull the rainbow cord out by using the iFixit opening tool on each side of its connecting slot.
Remove the M2.5 x 3mm screw that holds down the battery by using the Phillips #00 screwdriver.
Lift the battery up from its edges and pull back slightly towards the hinges to remove the battery.
This is where your laptop's RAM memory stick is located in the motherboard.
There are two (2) side clips securing the existing RAM memory stick on your laptop.
Pull the side clips away from the existing RAM memory stick in the direction marked by the arrows. This will unlock the RAM memory stick.
