Введение
This guide will show how to remove the keyboard. Removing the keyboard will allow you to replace it or inspect the keys if there is a mechanical problem.
Выберете то, что вам нужно
Place the netbook bottom-side-up on a flat surface.
Locate the unlock latch on the top right corner of the back.
To unlock the battery, slide the lock latch in the direction indicated by the unlocking icon. You should see the orange indicator which means that the latch is unlocked.
On the opposite side, slide and hold the release latch.
Gently slide the battery out.
Locate the three latches along the top crevice along the top rows of keys and the plastic boarder.
Using the metal spudger, gently pry each tab releasing the keyboard. Make sure as you move to each new one that the previous one does not reset itself.
Check for tabs on the side of the keyboard.
If there are no tabs lift the top of the keyboard.
Locate the sticker-like connecter on the back of the keyboard. Carefully unplug it.
3 участников успешно повторили данное руководство.
