Введение
Hard drives or HDDs contain all of the programs and files used by your computer. It’s important to make sure yours is working correctly. If it does not work correctly, it can drastically slow your computer down and even render it useless.
If you’re experiencing data issues or simply running out of space, follow along with this guide to replace the hard drive in your Acer Aspire One 722 in no time.
Prior to beginning the guide, power off your device and remove the battery.
Выберете то, что вам нужно
Power down the netbook by pressing the power button on the top left corner.
Slide the button below the battery to the right while simultaneously pulling the battery out.
With the battery cavity facing away from you, use the Phillips #0 to remove the center screw which secures the backplate.
With the backplate removed, locate the HDD in the upper left corner of the device.
Use the Phillips #0 screwdriver to remove the four corner screws securing the HDD to the chassis.
Gently lift and secure the HDD with one hand and carefully remove the SATA and power connections with your other hand.
With your replacement HDD in hand, reseat the power and SATA cables removed from the previous drive.
With the cables attached, align the four mounting points in the corner of the drive with the chassis and reseat the four Phillips #0 screws that were removed earlier.
To reassemble your device, follow these instructions in reverse order., taking special care in replacing the back cover. and battery.
4 участников успешно повторили данное руководство.
