Введение
If your Acer Aspire One 722 isn’t producing clear visuals - distorted, cracked, or dented - use this repair guide to safely replace the screen.
Before using this guide, inspect the screen for debris that may be interfering with the visual quality. Be sure to test the quality of the screen by turning on the device to confirm the screen is faulty and is in need of replacement.
Step 5 requires you to slowly remove the glass casing from the device. Visit your local electronics store that recycles used materials to safely dispose of the faulty screen.
Before beginning, make sure to power off your device completely and disconnect from any external power source.
Выберете то, что вам нужно
Power down the netbook by pressing the power button on the top left corner.
Slide the button below the battery to the right while simultaneously pulling the battery out.
Remove the black rubber clips from the bottom right and left of the netbook screen.
On the bottom left of the screen there is a cord attached. Remove the tape that is attached to the screen.
4 человек успешно провели ремонт по этому руководству.
