Введение
Use this guide to replace the fan in the Acer Aspire One 751h-1948
Выберете то, что вам нужно
Unlock the right side of the battery by sliding the battery lock to the right. Then slide the left lock to the left and remove the battery.
Unscrew the two Phillips #0 (M2-L2.5 mm) holding down the network card panel.
Remove the screw Phillips #0 (M2-L3 mm) holding down the network card. Pull out the card.
Unscrew the Phillips 0# (M2 L2.5 mm) screw and remove the cover panel.
Use the plastic opening tool to push in each of the four clips and carefully lift the keyboard.
When you remove the keyboard, be careful not to damage the ribbon cable that attaches it to the motherboard.
Unplug the ribbon cable by gently lifting the black tab up. Then remove the cable.
Use the screwdriver to remove all the Phillips #00 (M2-L2.5 mm) screws shown here.
Flip the laptop over and remove all the Phillips #0 (M2-L5 mm) screws under the keyboard.
Remove all the Phillips #0 (M2-L2.5 mm) screws
Separate the front panel from the back panel, by sliding your thumb nail between them.
Remove the ribbon cable that sits on top of the fan by lifting the small black clip and pulling the blue tab.
Use the same technique to remove the ribbon cable from the motherboard.
