Введение
This guide will help you replace the network card of the Acer Aspire One 751h-1948.
Выберете то, что вам нужно
Unlock the right side of the battery by sliding the battery lock to the right. Then slide the left lock to the left and remove the battery.
Unscrew the two Phillips #0 (M2-L2.5 mm) holding down the network card panel.
Remove the screw Phillips #0 (M2-L3 mm) holding down the network card. Pull out the card.
Почти готово!
Заключение
