Введение
If the life of your battery is significantly shortened, it may be damaged or old. This guide can help you replace the battery by yourself!
Выберете то, что вам нужно
Identify the HDMI port located in the side of the laptop opposite to the power button.
Insert the plastic opening tool into the divet of the back panel located above the HDMI port.
Pry along the laptop frame until the back panel comes loose.
Rotate the device so the opening faces you again.
Hold the back panel away from the laptop and remove the 4-mm screw using the PH0 screwdriver.
Lift the back panel gently.
Unplug the cable that connects the battery to the motherboard.
Detach the back panel, which still includes the battery.
Remove the 5-mm screw that is located underneath the rubber foot using the PH0 screwdriver.
Lift the battery and detach it from the back panel.
Еще один человек закончил это руководство.
