Введение
The USB port allows you to connect other devices to the laptop. This guide will show you how to remove and replace the USB port.
Выберете то, что вам нужно
Insert a plastic opening tool under the bottom cover and slid it around the perimeter until all of the clips release.
Use a spudger to flip up the retaining flap on the ribbon cable ZIF socket.
Remove the ribbon cable from the socket.
Remove the 5mm Phillips #0 screw from the USB port.
Remove the USB port from the device.
