Введение
Speakers will wear down over time. This guide will show you how to replace your speakers. All that is required to replace your speakers is a philips screwdriver to remove the cover.
Выберете то, что вам нужно
Once the panel is removed, you will see two speakers that is attached to the motherboard by a black cord.
Pull the cord gently to remove, you may have to wiggle the cord if it does not come out smoothly.
Repeat the process to remove the other cord.
Pull upwards to remove the speaker.
Repeat the process to remove the second speaker.
Еще один человек закончил это руководство.
