Введение
The fan actively cools your computer. The fan is important for keeping key components cool and ensuring your computer functions properly. When the fan malfunctions the computer could overheat and this would damage critical components within the computer.
If this occurs check the fan for excessive dust or any debris. If there is debris or your fan is making loud unusual sounds follow this guide to replace your fan.
Выберете то, что вам нужно
Pull the upper left switch on the back of the laptop to the left into the unlock position.
Pull the upper right switch to the left and hold it in place.
Use iFixit’s Jimmy tool to remove bottom panel of device.
Wedge the tool into the top middle of the panel until the back gently pops off.
Use the tweezers to disconnect the fan's wires from laptop.
Use the Phillips #1 screwdriver to remove the three 4mm screws that hold the fan in place.
