Acer Aspire One D257 Wireless card Replacement
Выберете то, что вам нужно
  1. Acer Aspire One D257 Wireless card Replacement, Battery: шаг 1, изображение 1 из 1
    • Put the netbook, so the back side is upwards.
  2. Acer Aspire One D257 Wireless card Replacement: шаг 2, изображение 1 из 1
    • Push the right lock to the right so the red filed is visible on the left.
  3. Acer Aspire One D257 Wireless card Replacement: шаг 3, изображение 1 из 1
    • Now move the left lock which is spring loaded to the leftand keep it there. Then with the other hand remove the battery by pulling down.
    • When reassembeling the new battery push it up into the netbook and do lock the right by moving it to the left so the red field disappears.
  4. Acer Aspire One D257 Wireless card Replacement, Keyboard: шаг 4, изображение 1 из 2 Acer Aspire One D257 Wireless card Replacement, Keyboard: шаг 4, изображение 2 из 2
    • Open the lid othe the netbook. Use the Jimmy from the upper left corner of the keyboard. Put it between the keyboard and th casing and move it to the right. It might help to use a metal spudger to push in the pins holding the keyboard in place.
    • Then move down along the sides where there is one pin on each side. After that twist the keyboard towards you.
  5. Acer Aspire One D257 Wireless card Replacement: шаг 5, изображение 1 из 1
    • Now open the brown connector so the flat cable is loose. Then you can remove the keyboard.
  6. Acer Aspire One D257 Wireless card Replacement, Acer Aspire One D257 opening the hatch: шаг 6, изображение 1 из 1
    • Remove the 5 screws marked with "Door".
  7. Acer Aspire One D257 Wireless card Replacement: шаг 7, изображение 1 из 2 Acer Aspire One D257 Wireless card Replacement: шаг 7, изображение 2 из 2
    • Use a spudger or flat screwdriver to push down the hatch where it is marked "Door release".
    • Now you can carfully remove the hatch.
    • When reassembling the hatch look that the noses are aimed at the appropriate holes in the case, then you can press down the rest of the hatch onto the netbook.
  8. Acer Aspire One D257 Wireless card Replacement, Wireless card: шаг 8, изображение 1 из 1
    • Turn around the netbook so we look on the bottom.
  9. Acer Aspire One D257 Wireless card Replacement: шаг 9, изображение 1 из 3 Acer Aspire One D257 Wireless card Replacement: шаг 9, изображение 2 из 3 Acer Aspire One D257 Wireless card Replacement: шаг 9, изображение 3 из 3
    • With an anti static spudger carfully remove the antenna cables from the connection on the WiFi-card.
    • Remove the screw to then lift the card from the socket.
    • Now you can install a new or better WiFi-card. I have installed a Dualband AC card from Intel into my netbook, the AC 7260.
Заключение
4 участников успешно повторили данное руководство.
Особая благодарность этим переводчикам:
de en
100%
Эти переводчики помогают нам починить мир! Хотите внести свой вклад?
Начните переводить ›
Claes
Участник с: 02/01/16
3 400 Репутация
Автор 6 руководств
Команда
Master Techs Участник Master Techs
Community
322 членов
Автор 2 519 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 22
За всё время: 3,212
