Введение
If your hard drive is no longer working, this guide will help you replace it.
Выберете то, что вам нужно
Locate the 4 mm Phillips #1 screw at the bottom of the back panel. Using the Phillips head screwdriver, remove the screw. Place the screw somewhere it will not be lost. Then remove the back panel by gently sliding it towards the front.
Locate the two 4 mm Philips #1 screws holding the hard drive into its bracket.
Remove the two screws and place them somewhere they will not be lost.
2 Комментарии к руководству
tiene 4 ram hasta cuanto soporta gracias...
Was reviewing this to see if it was possible to reattach the drive connector if removed. (dealing with this in this model of laptop)
