Введение
This guide aims to help the user to remove and replace the screen/touch screen on the Acer Aspire R5-471T-52EE. The screen may fail for many reasons and may need to be replaced in order for the user to properly use the Acer Aspire again.
Выберете то, что вам нужно
With the hinges of the laptop pointing away from you, gently begin to pull on the portion between the two hinges towards yourself until you feel the cover pop off.
Remove the back cover from the device.
Disconnect the three wires from the motherboard that connect to the screen.
Remove the eight 3mm screws on the hinges using the Phillips #1 screwdriver.
Now that the hinges have been unfastened, carefully separate the screen and screen casing from the other half of the computer.
Using a spudger or an opening pick, pop open the case holding the screen. Follow the line where the two pieces of the case meet all around the screen.
Remove the display assembly from the device.
To install the screen and reassemble your device, follow these instructions in reverse order.
