Введение
This guide will show the reader how to replace the motherboard in their Acer Aspire R5-571T-59DC.
Motherboards are a tricky component to replace because every other component in the computer must be disconnected and reconnected to the new motherboard. Be gentle in handling each component and store them in a safe place during the replacement process.
Be sure to keep track of the screws holding each component in place and use the guide to make sure you re-plug each component in the right place.
And please make sure the device is powered off and unplugged before doing any work on it to avoid harming the electronics.
Выберете то, что вам нужно
Disconnect all power from the laptop and turn over so the bottom is facing you.
Remove the twelve 07.mm Phillips #0 screws from the back cover.
Work a plastic opening tool underneath and around the perimeter of the bottom cover.
Once unclipped, remove the bottom cover.
Remove the two 0.7mm Phillips #00 screws from the battery and unplug the battery from the motherboard.
Lift the battery out of the case.
Use a spudger to flip up the retaining flap on the hard drive ribbon cable ZIF socket.
Pull the ribbon cable out of the socket.
Lift up the protective covering away from the RAM using tweezers, or your fingers.
Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
Lift the RAM module to an angle of about 30 degrees and slide it out.
Use a spudger to flip up the retaining flaps on all of the ribbon cable ZIF sockets.
Pull the ribbon cables out of the sockets.
Lift up and remove the motherboard.
Один комментарий
Hi, my laptop is Acer R5-571TG-765T.
1. Does the bare bones motherboard have the same physical configuration as your R5-571T-59DC?
2. Is M.2 NVMe SSD compatible with my motherboard?
3. My laptop runs hot even with a cooling fan stand beneath. Would you recommend NVMe?
4. If heat is a problem, and availability of reputable and affordable M.2 SATA is lacking where I am -- will I be able to use a 2.5" SATA SSD as a boot drive and keep my existing 2.5" SATA HDD as a D drive at the same time?
Thank you!
