Выберете то, что вам нужно
Remove seven 10 mm T7 screws.
Remove four 6 mm T7 screws.
Use the blue plastic opening tool to carefully remove both rubber pads which cover the four remaining screws.
Remove the remaining four 10 mm T7 screws.
Locate the AC Socket ribbon connector
Loosen the ribbon connector using the plastic opening tool
Pull the ribbon connector away from the motherboard
Use the plastic opening tool to pry up on the yellow tabs holding the Socket in place
Once the tape on the Socket is loose, pull up and away from the case to remove it.
Еще один человек закончил это руководство.
