ΠŸΠ΅Ρ€Π΅ΠΉΡ‚ΠΈ ΠΊ основному ΡΠΎΠ΄Π΅Ρ€ΠΆΠ°Π½ΠΈΡŽ
Π’Π²Π΅Π΄Π΅Π½ΠΈΠ΅
This guide will demonstrate the steps to replace laptop ACER ASPIRE R7 RAM
Π˜Π½ΡΡ‚Ρ€ΡƒΠΌΠ΅Π½Ρ‚Ρ‹
Запчасти
Π”Π΅Ρ‚Π°Π»ΠΈ Π½Π΅ ΡƒΠΊΠ°Π·Π°Π½Ρ‹.
  1. Shut down the laptop and disconnect the power cord.
    • Shut down the laptop and disconnect the power cord.
    • Failing to disconnect or shut down the laptop could result in damage to the laptop or a shock hazard.
    • Turn the laptop over.
  2. Remove seven 10 mm T7 screws. Remove four 6 mm T7 screws. Use the blue plastic opening tool to carefully remove both rubber pads which cover the four remaining screws.
    • Remove seven 10 mm T7 screws.
    • Remove four 6 mm T7 screws.
    • Use the blue plastic opening tool to carefully remove both rubber pads which cover the four remaining screws.
    • Remove the remaining four 10 mm T7 screws.
  3. Carefully lift the cover upwards.
    • Carefully lift the cover upwards.
    • If the cover seems stuck, use a spudger tool to pry the sides.
Π—Π°ΠΊΠ»ΡŽΡ‡Π΅Π½ΠΈΠ΅
F Fernandez
Участник с: 13.01.2015
435 РСпутация
Автор 2 руководств
Команда
USF Tampa, Team 3-4, Hickman Winter 2015 Участник USF Tampa, Team 3-4, Hickman Winter 2015
USFT-HICKMAN-W15S3G4
4 Ρ‡Π»Π΅Π½ΠΎΠ²
Автор 7 руководств
ΠšΠΎΠΌΠΌΠ΅Π½Ρ‚Π°Ρ€ΠΈΠ΅Π²: 0
Π”ΠΎΠ±Π°Π²ΠΈΡ‚ΡŒ ΠΊΠΎΠΌΠΌΠ΅Π½Ρ‚Π°Ρ€ΠΈΠΉ
ΠŸΡ€ΠΎΡΠΌΠΎΡ‚Ρ€ статистики:
Π—Π° послСдниС 24часов: 0
Π—Π° послСдниС 7 Π΄Π½Π΅ΠΉ: 0
Π—Π° послСдниС 30 Π΄Π½Π΅ΠΉ: 0
Π—Π° всё врСмя: 106
