Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Shut down the laptop and disconnect the power cord.
Turn the laptop over.
Remove seven 10 mm T7 screws.
Remove four 6 mm T7 screws.
Use the blue plastic opening tool to carefully remove both rubber pads which cover the four remaining screws.
Remove the remaining four 10 mm T7 screws.
Locate the clip attaching the right-side speakers to the motherboard.
Carefully pull on the clip until it detaches from the motherboard.
Remove the two 3.5mm #00 Phillips screws which hold the speaker in place.
Carefully lift the right-side speaker assembly away from the motherboard.
Locate the clip attaching the left-side speakers to the motherboard.
Carefully lift the left-side speaker assembly away from the motherboard.
