Введение
If there is an issue with the charging port on your Acer Aspire, there might be an issue with the power connector. If your laptop is not charging or is charging irregularly, replacing the power connector might help alleviate these issues.
Выберете то, что вам нужно
Turn off your laptop and disconnect the power adapter.
Locate and remove all 12 Phillips #00 6mm screws on the backside of the laptop.
Disconnect the wiring from the motherboard, and pull out the rest of the wire carefully.
Еще один человек закончил это руководство.
4 Комментариев
50.mqpn7.001 (SIQDD0ZS8AD001)
I found it here: https://www.itpartsource.com/50MQPN7001-...
