Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
This guide will walk you through accessing the battery. The battery may need be accessed for replacement or repair. Be careful not to puncture or damage the battery, and dispose of it immediately if it begins to heat up while disconnected.
Запчасти
Детали не указаны.
  1. Remove the 12 5mm Phillips #00 screws. Use a plastic opening tool to gently pry open the back panel. Gently lift up the back panel, exposing the internals of the laptop.
    • Remove the 12 5mm Phillips #00 screws.
    • Use a plastic opening tool to gently pry open the back panel.
    • Gently lift up the back panel, exposing the internals of the laptop.
  2. Unscrew the 4 1mm PH00 screws attaching the speakers to the frame. Unscrew the 4 1mm PH00 screws attaching the speakers to the frame.
    • Unscrew the 4 1mm PH00 screws attaching the speakers to the frame.
  3. Manta Driver Kit
    112 bits for every fix.
    Upgrade Your Toolbox
    Manta Driver Kit
  4. Gently remove the speakers. Note that the wire connecting them may be lightly glued down. If so, gently pry up.
    • Gently remove the speakers. Note that the wire connecting them may be lightly glued down. If so, gently pry up.
  5. Gently lift the battery from the frame.
    • Gently lift the battery from the frame.
Заключение
2 участников успешно повторили данное руководство.
Nikolas I Steckley
Участник с: 17.09.2018
635 Репутация
Автор 5 руководств
Команда
Washington State, Team S1-G4, Hope Fall 2018 Участник Washington State, Team S1-G4, Hope Fall 2018
WSU-HOPE-F18S1G4
3 членов
Автор 6 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 13
За последние 30 дней: 107
За всё время: 1,945
