Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide will walk you through accessing the battery. The battery may need be accessed for replacement or repair. Be careful not to puncture or damage the battery, and dispose of it immediately if it begins to heat up while disconnected.
Выберете то, что вам нужно
Remove the 12 5mm Phillips #00 screws.
Use a plastic opening tool to gently pry open the back panel.
Gently lift up the back panel, exposing the internals of the laptop.
Gently remove the speakers. Note that the wire connecting them may be lightly glued down. If so, gently pry up.
2 участников успешно повторили данное руководство.
