Введение
This guide will walk you through removing the speakers. The speakers may need to be removed if they are damaged, or just to access the components beneath them.
Инструменты
Запчасти
Детали не указаны.
Remove the 12 5mm Phillips #00 screws.
Use a plastic opening tool to gently pry open the back panel.
Gently lift up the back panel, exposing the internals of the laptop.
Gently remove the speakers. Note that the wire connecting them may be lightly glued down. If so, gently pry up.
Почти готово!
Заключение
