Введение
The battery is what allows the computer to turn on without being plugged into the wall. If your laptop does not turn on or does not stay on for very long when it is unplugged, then the battery may need to be replaced. The goal of this guide is to show how to remove and replace a faulty battery. It is also a pre-requisite guide for other guides that require you to open up your laptop. The battery is the largest internal piece of the laptop, and is easy to locate when the device is opened up. For this guide, a plastic opening tool and a Phillips #0 screwdriver will be utilized. The steps for replacing the battery involve removing several screws and cables and will take approximately fifteen to twenty minutes to complete.
Removing the battery should likely the be the first step before removing or replacing any other part of the laptop. By removing the battery first, electric discharge and damage to internal components can be avoided.
Выберете то, что вам нужно
Keeping it closed, turn the laptop upside down.
With the Phillips #0 screwdriver, remove the twelve 5 mm screws that hold the laptop together.
Insert the plastic opening tool between the plastic casings to pull the bottom lid of the laptop up.
Locate the six cables that are connected to the motherboard. The cable with the white strip is located underneath the cable with the orange strip.
Using the plastic opening tool on one side and your fingernail on the other, wedge each cable out of its socket.
With the Phillips #0 screwdriver, remove the two 5 mm screws that are located above the long black piece of the battery.
Locate the two speakers for this laptop that are connected above the battery by a thin red cord.
Using the Phillips #0 screwdriver, remove the two 3 mm screws holding the left speaker in place.
Pull the left speaker up along with the red cord and leave it off to the right side.
Without bending it, lift the entire battery (both the long black piece and the rectangular blue piece) straight up. Place it off to one side.
Один комментарий
Hello there! How about CMOS battery of this model Acer Apire S3 951? I can’t find it where to change or replace.. I hope you can provide me procedure. God bless ang more power to you iFixit.
