Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Keeping it closed, turn the laptop upside down.
With the Phillips #0 screwdriver, remove the twelve 5 mm screws that hold the laptop together.
Insert the plastic opening tool between the plastic casings to pull the bottom lid of the laptop up.
Locate the six cables that are connected to the motherboard. The cable with the white strip is located underneath the cable with the orange strip.
Using the plastic opening tool on one side and your fingernail on the other, wedge each cable out of its socket.
With the Phillips #0 screwdriver, remove the two 5 mm screws that are located above the long black piece of the battery.
Locate the two speakers for this laptop that are connected above the battery by a thin red cord.
Using the Phillips #0 screwdriver, remove the two 3 mm screws holding the left speaker in place.
Pull the left speaker up along with the red cord and leave it off to the right side.
Without bending it, lift the entire battery (both the long black piece and the rectangular blue piece) straight up. Place it off to one side.
Один комментарий
Hello there! How about CMOS battery of this model Acer Apire S3 951? I can’t find it where to change or replace.. I hope you can provide me procedure. God bless ang more power to you iFixit.
