Введение
The fan often needs replacement if the device is overheating or making loud noises while running. Some common tools will be needed for this replacement, such as a T6 Torx screwdriver and a Phillips #01 screwdriver. To determine if the fan needs to be replaced, please refer to this device's troubleshooting page.
Выберете то, что вам нужно
Remove the back panel by unscrewing all marked 3mm screws with a T6 Torx screwdriver.
Remove these screws with a T6 Torx screwdriver, but note that these feet screws are 4mm in length.
Unscrew the marked 2mm screws with a Phillips #01 screwdriver.
Remove the fan by disconnecting the marked tabs.
Еще один человек закончил это руководство.
