Запчасти
Никакие детали не требуются.
  1. Remove the back panel by unscrewing all marked 3mm screws with a T6 Torx screwdriver. Remove these screws with a T6 Torx screwdriver, but note that these feet screws are 4mm in length.
    • Remove the back panel by unscrewing all marked 3mm screws with a T6 Torx screwdriver.
    • Remove these screws with a T6 Torx screwdriver, but note that these feet screws are 4mm in length.
  2. Unscrew the marked 2mm screws with a Phillips #01 screwdriver. Remove the fan by disconnecting the marked tabs.
    • Unscrew the marked 2mm screws with a Phillips #01 screwdriver.
    • Remove the fan by disconnecting the marked tabs.
  3. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  4. Remove the marked 2mm screw with a Phillips #01 screwdriver.
    • Remove the marked 2mm screw with a Phillips #01 screwdriver.
  5. Remove the hard drive by pulling it away horizontally from its connection.
    • Remove the hard drive by pulling it away horizontally from its connection.
Заключение
Nicholas Wise
Участник с: 14.02.2018
595 Репутация
Автор 5 руководств
Команда
USF Tampa, Team S2-G6, Eyestone Spring 2018 Member of USF Tampa, Team S2-G6, Eyestone Spring 2018
USFT-EYESTONE-S18S2G6
3 членов
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 1
За 7 дней: 19
За 30 дней: 56
За всё время: 251
