Введение
The hard drive is the storage location for the laptop's memory and processing, the data compartment. This guide offers step by step instructions to replace the hard drive.
Выберете то, что вам нужно
Turn laptop so under side is facing up.
Locate the hard drive door and unscrew the 5 screws using PH0 mm Phillips Head.
Remove screw attached to the hard drive using the PH0 mm Phillips Head.
The hard drive can now be removed from the device.
