Введение
The hard drive on a computer is typically used to access laptop applications. Use this guide to replace broken hard drives, which tend to be the most common laptop component to fail. No complicated manipulation is required.
Запчасти
No parts specified.
  1. To release the battery, slide the orange tab to the right with a spudger. The battery is now released and can be picked up and set to the side.
    • To release the battery, slide the orange tab to the right with a spudger.
    • The battery is now released and can be picked up and set to the side.
  2. Remove the two 5.3 mm Phillips #0 screws. Remove the two 5.3 mm Phillips #0 screws.
    • Remove the two 5.3 mm Phillips #0 screws.
  3. iPhone Battery Fix Kits
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  4. Pull off the back panel. Pull off the back panel.
    • Pull off the back panel.
  5. Pull the plastic tab on top of the hard drive.
    • Pull the plastic tab on top of the hard drive.
  6. Remove the four 5.3 mm screws that secure the hard drive in the frame. Remove the four 5.3 mm screws that secure the hard drive in the frame.
    • Remove the four 5.3 mm screws that secure the hard drive in the frame.
Заключение
After replacing the old hard drive, reassemble your device by following these instructions in reverse order.
Maritsa Garcia
Участник с: 22.10.2018
782 Репутация
Автор 5 руководств
Команда
Baylor, Team S1-G4, Williams Fall 2018 Member of Baylor, Team S1-G4, Williams Fall 2018
BU-WILLIAMS-F18S1G4
3 членов
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 4
За всё время: 122
